I've seen a couple of people talk about using "dry sponge" to darken an area around the edges of a project where the middle is a different and lighter color. Explain to me how to do this, please.
I may be wrong, but it sounds like block dyeing, except with a sponge rather than a wooden block. Basically, it's a dry (doh!) sponge, either wrapped with a cloth, or not... dye is applied & then blotted on newspaper or a blotter to remove most of the dye. Then it's rubbed around the area you wish to work, lightly where you want very little darkening & heavier where you want more. Wear rubber or latex gloves, for obvious reasons. Or not... :spoton:
Is this the kind of effect that can be obtained with an airbrush? So that the dye fades from dark at the edge to light near the middle?
To some extent, yes. But, an airbrush will not give you the mottled, rustic look that the sponge technique will produce.
Ah right, I see. Thanks.
