reddevil76 Report post Posted August 24, 2011 After removing the blade to strop it, I can't for the life of me position the blade back to work as it should. I tried 2 positions: - One parallel to the roller, slightly behind the top line (imaginary line) of the roller - There is a bar in front of the blade, it is slanted instead of parallel to the roller. I tried aligning the blade to this bar, also no go. Quote Share this post Link to post Share on other sites
seveneves Report post Posted September 2, 2011 After removing the blade to strop it, I can't for the life of me position the blade back to work as it should. I tried 2 positions: - One parallel to the roller, slightly behind the top line (imaginary line) of the roller - There is a bar in front of the blade, it is slanted instead of parallel to the roller. I tried aligning the blade to this bar, also no go. You know I've had the same problem. It seemed like when I bought it the blade was slanting. I've tried to fix it but didn't really do it right Quote Share this post Link to post Share on other sites
