Hello all,
I'm new to this forum, but let me say how impressed I have been with the amount of knowledge and info available here... thanks to everyone that's contributed!
I'm in the market for a heavy-duty machine... problem is, I'm not really sure models I should be considering.
I will be making safety harnesses, sewing through fairly thick work consisting of foam, layers of webbing, etc. Walking foot mandatory. Pretty high lift foot would be really useful, and a large bobbin would be nice but isn't mandatory. Reverse IS mandatory. I also require a machine that can use 207 thread.
I have some experience on a Juki LU-563, but am told it will not sew 207 thread? I could also use a higher lifting foot than the 563, although I was able to squeeze stuff under there with some effort.
I did some shopping and was told with certainty (by a salesman mind you) that the Juki 1508NH was THE machine for me... but at ~$2400, it's a bit out of my range. I've also been told not to buy new?
Any advice on some models to consider would be GREATLY appreciated!!! Or if you have a 1508NH (used), or something appropriate for my needs, that you'd be willing to part with????
I'm located in Utah, but am willing to travel for the right machine. Thanks so much for your help....
-Ryan
You should get in touch with the gentleman that runs a harness shop in Troy, Montana. I don't know your limit of "willing to travel". He has some sewing machines that might me what you are looking for. Northwest Harness is the name of the shop.The last time I talked to him he had a couple of used Juki 441's.
Edited by busted
