Members altpersona Posted September 19, 2011 Members Report Posted September 19, 2011 I am starting my first project. actually Im destroying some stuff to get some practice before I start my first project. I picked up some tandy leather cement from my local hobby lobby today, I just glued a handkerchief to some suede. As I was doing that it occurred to me that the glue smelled just like Elmers wood glue. should I skip the hobby store next time and just grab the Elmers? on a separate, related topic. I think I want ( i know im sick) to hand stitch my projects, and I was thinking of mounting a nice solid needle in a drill press. I dont need the spinning, but the press and chuck seem perfect for quick controlled holes. am I crazy? (for the drill press, not hand stitching ) Quote
terrymac Posted September 19, 2011 Report Posted September 19, 2011 I use my drill press all the time to do just what you discussing. I bought a Tandy awl handle and pulled the chuck out of the handle and insert the 1/4" round shaft in the drill press. It works great. The only trick I have learned is to turn on the drill press to make sure the chuck is positioned correctly. If it isn't, you will see a woobly spinning. Use a prickling wheel, mark your hole layout and go to punching holes. You want your awl blade angled, just watch it to make sure it stays in the same alignment as it can move. Can't answer your question concerning the wood glue, but a lot of members on this forum use Wood Weld and seem happy. I use Tandy contact cement with no problems. Hope this helps. Terry Quote
King's X Posted September 20, 2011 Report Posted September 20, 2011 Is that Tandy glue called 'Leather Weld?' Comes in a bottle that looks just like the Elmer's bottle and even white in color. Quote
Members altpersona Posted September 20, 2011 Author Members Report Posted September 20, 2011 http://www.tandyleatherfactory.com/en-usd/home/2540-130.aspx Quote
Denster Posted September 21, 2011 Report Posted September 21, 2011 I am starting my first project. actually Im destroying some stuff to get some practice before I start my first project. I picked up some tandy leather cement from my local hobby lobby today, I just glued a handkerchief to some suede. As I was doing that it occurred to me that the glue smelled just like Elmers wood glue. should I skip the hobby store next time and just grab the Elmers? on a separate, related topic. I think I want ( i know im sick) to hand stitch my projects, and I was thinking of mounting a nice solid needle in a drill press. I dont need the spinning, but the press and chuck seem perfect for quick controlled holes. We had a big somewhat contentious conversation about this on the holster thread a couple of years back. I did some tests on leather weld and Elmer's white wood glue. They look smell and taste the same. They have the same glueing charictaristics and leather weld will bond to Elmer's. Not the first time a company has repackaged a product. am I crazy? (for the drill press, not hand stitching ) Quote
Members altpersona Posted September 21, 2011 Author Members Report Posted September 21, 2011 thanks for the replies i know im in the right spot when taste testing glues is par for the course. Quote
Denster Posted September 21, 2011 Report Posted September 21, 2011 All in the name of science. thanks for the replies i know im in the right spot when taste testing glues is par for the course. Quote
