Hi, I see some machines advertised where some sub models have standard hooks and some have large hooks. What practical difference does that make on the machine? Thanks.
Andrew
Andrew
Andrew;
A standard hook uses a bobbin that is about the same size as a Singer 15 class machine: 3/4" by just under 3/8". You can see those bobbins at any local sewing supplies store, including Joann Fabrics. They hold a pretty fair amount of thin thread, such as is used in sewing garments.
A large hook holds a bobbin that is 1 inch in diameter by 11/32" high. It holds about 50% more thread. This extra capacity allows garment manufacturers to sew more between bobbin loads. It also allows upholsters and leather crafters to use #138 thread and not run out after a couple belts are sewn.
Juki is a horse of another color. Some of their big bobbin machines have a double capacity hook and special bobbins that hold about twice the amount of a standard one.
Posted IMHO, by Wiz
  On 10/24/2011 at 3:32 PM, Wizcrafts said:
Andrew;
So hook size simply refers to bobbin size and not some other function? That's good to know. Thanks.
Andrew
Andrew
Negatory Red Rider.
A large hook-shuttle usually has more clearance around the bobbin case, allowing you to use thicker thread.
Posted IMHO, by Wiz
  On 10/24/2011 at 7:05 PM, Wizcrafts said:
Negatory Red Rider.
I think that also the thread tension with larger hooks is more constant with a large hook, so the seam quality is better. Dürkopp has posted some information with pictures about that.
