Members tomasito Posted October 29, 2011 Members Report Posted October 29, 2011 I tried to search for information on the Pfaff 335 H3 on this forum. I just purchased one with a table and motor, but it did not come with a manual and I don't know enough about it. Like what is the needle system it uses, what bobbin case should I get 9mm,12mm or 14mm( does it share Pfaff 138 bobbin case? ) Does someone have access to the service manual and instruction manual? Any help is very appreciated, thanks in advance. Quote
Members busted Posted October 29, 2011 Members Report Posted October 29, 2011 I tried to search for information on the Pfaff 335 H3 on this forum. I just purchased one with a table and motor, but it did not come with a manual and I don't know enough about it. Like what is the needle system it uses, what bobbin case should I get 9mm,12mm or 14mm( does it share Pfaff 138 bobbin case? ) Does someone have access to the service manual and instruction manual? Any help is very appreciated, thanks in advance. This might be what you are looking for. http://www.sewingmanuals.com/Sewing_Machine_Manuals/Pfaff_Industrial.htm Quote
Members tomasito Posted October 29, 2011 Author Members Report Posted October 29, 2011 Thanks, but they don't have any manuals for the Pfaff 335 H3, I wonder if the newer 335 manual would work? Quote
Ambassador leatheroo Posted October 29, 2011 Ambassador Report Posted October 29, 2011 (edited) Hi, i have just bought a pfaff 335 17B H2S , this is the manual that i have been using. Great machine, just toooooo fast, i am trying to get a servo motor for it. It uses the 134-35 needle system. At the moment i have a size 22 needle in it and using 138 size thread. My bobbin measures 22mm in diameter and 9mm wide cheers ba_335_06-09_e.pdf Edited October 29, 2011 by leatheroo Quote "]http://leatheroo.blogspot
Members tomasito Posted October 30, 2011 Author Members Report Posted October 30, 2011 Hi, i have just bought a pfaff 335 17B H2S , this is the manual that i have been using. Great machine, just toooooo fast, i am trying to get a servo motor for it. It uses the 134-35 needle system. At the moment i have a size 22 needle in it and using 138 size thread. My bobbin measures 22mm in diameter and 9mm wide cheers ba_335_06-09_e.pdf Thanks for the pdf. I also have a Pfaff 145 that uses the same needles. I think I'll try a 23 size and some 138 thread. I just found out that the 335 H3 uses the same bobbin case as the Pfaff 138. Someone out there must have a manual for the 335 H3... Quote
Members jamann Posted March 21, 2012 Members Report Posted March 21, 2012 Hello tomasito, I see that we have the same problem. A few days ago I bought a sewing machine Pfaff 335 H2-17/1B. I searched online service manual our instruction manual, but was only to new models of Pfaff 335th Did you find the manual for the model you have. I think the manual from the Pfaff 335 H3 fits my Pfaff H2. I have bobbin dimensions: height 9 mm diameter 21 mm and I have number of needles Groz - Beckert 134 DPx5 135x5 Quote
