Members HCM Posted October 31, 2011 Members Report Posted October 31, 2011 Am I the only person who has some issues with needle positioner motors? I do relatively high end work, and am very particular about where my needle goes. On some of my pieces, 0.5mm off and my piece is destroyed. So, I like to be able to stitch slow and let the needle stop right before it hits the material so I can position the piece if the needle is off its mark a little bit. For the most part, the fly wheel can be cranked by hand to get the needle to this position, but that means hand cranking the majority of a revolution if the positioner is set to stop in the needle down position. I could set it to stop in the needle up position, but then I have to hand crank every stitch where the piece needs to be turned with the needle down. So, I was wondering if there is a motor option that will let me disable the positioner for certain operations. But really, am I the only person who has these issues? Quote
Members amuckart Posted October 31, 2011 Members Report Posted October 31, 2011 How old is the servo driver your'e using? Modern ones should configurable to stop at almost any position you want. I don't know if commercial ones can do this, but I've seen a home-built servo controller that had a mode where the needle followed the pedal directly, so pushing the pedal down dropped the needle and lifting the pedal raised the needle. I don't know at what point it decided it had to transition through bottom dead centre though. Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
Members HCM Posted October 31, 2011 Author Members Report Posted October 31, 2011 I have an Efka and two Quick Rotans. None of them are very "modern", but the Quicks are newer. I didn't know I could mess with the position like that. What if it's on a machine with a thread trimmer and automatic functions, can I still change where it stops? Even still, sometimes when I stitch through some tricky areas I have to run the needle through slow so it doesn't get deflected in the piece and break. So, I still have issues, but like I said, we do some pretty tricky stitching. Quote
