The one in the first photo is the way I got this pitman arm why I bought it. Pretty cobbled up.
So I decided to make one up. This is a prototype the finish one will be made of hard Maple like the originals.
The dimensions are as followed.
Length 16 1/8" Thickness 1/2" From center of hole to center of hole is 13"
The first set of holes the holes the treadle and fly will ride on are done with a 1/2" forstner bit.
The second hole was done with a 5/8" forstner bit. These were cut on a drill press.
If you don't have the hardware I know the wood inserts can be made and I am sure with a little brain power
the metal hardware can be made.
"It ain't about how hard you hit. It's about how hard you can get hit and keep moving forward."
- Rocky Balboa
