Ok, so I've made dozens of holsters at this point and so far everyone wants black. Until now. Turns out, light brown is harder than it sounds. Luckily I tried some test pieces before I went crazy with the holster. One coat of Feibings light brown oil dye looks great when it's dry but when you get the leather wet for molding it turns DARK CHOCOLATE. I mean dark. I'm clearly missing something, just not sure what. I've already dyed the holster pieces so hopefully the step I'm missing doesn't come before that. I'm sure Murphy's law will somehow make an appearance though.
I found a post from johnggrg but that's the closest I could find to being the same issue. If anyone can help me out I would be eternally grateful.
Thanks in advance!!
Well, from the old grump, I'm at a total loss. I have absolutely no idea what happened. Here's a couple of pics of a rig I did earlier this year. They're done in a combo of saddle tan and dark brown oil dyes ---- thinned a bunch with denatured alcohol, and maybe close to the color you were working with/for.. The holster was wet molded after dying. The second pic shows the two matching holsters made. The one on the right, for this rig, and finished. The one on the left, a strong-side holster is unfinished. As said, I use oil dyes for almost all of my dye jobs, applied by airbrush --- never heard of such a thing. Mike
NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!!
At my age I find that I can live without sex..........but not without my glasses.
Being old has an advantage.......nobody expects me to do anything in a hurry.
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
What kind of leather are you using? I'm currently using Wickett & Craig.
How are you applying the dye?
Here is a Light Brown holster with Dark Brown accents around the edges. I apply the dye with an airbrush (4 coats). I also cut, dye, assemble, wet, form, bake, oil, seal - in that order (with a few other misc. steps tossed in). I only use Fiebing's Pro Oil dyes, and I never dilute them.
For what it's worth, here is another comparison. The first journal cover is cut from 5-6oz Herman Oak that I pulled from my scrap bin. For this, I used a folded piece of canvas dipped in Light Brown Pro Oil, then applied it in a circular motion first, then from left to right, then up and down - 3 coats. I then followed that up with a blotted piece of canvas (very little dye left) and dabbed on Dark Brown for a mottled effect. Then I oiled the whole piece. I dampened it to fold and hammer down the stitches - no darkening of the color (except for when I oiled it).
Here is a journal I made last night with the same colors, applied the same way. But, this time I used a cheap piece of 4-5oz that I bought on sale from Tandy a couple weeks ago. It came out MUCH darker and looked horrible until I put a finish on it, but it's still way too dark for what I intended (I wanted it more like the one above).
Edited by particle
FWIW; AH, YES --- the leather quality makes a difference. Again, FWIW, I WILL NOT purchase leather from the 'T' place. Mike
Particle, you've helped me out a few times in the past and I appreciate your efforts, along with everyone else who has tried to help me figure this out.
I think we may have a winner. I'm using a piece of leather from Tandy that was surprisingly nice (I thought). It works fantastic for black holsters. When I look at the difference in color between your Hermann Oak and the Tandy I can see the color similarities in the problem I'm having. I'm using a wool dauber to apply because I don't have an airbrush setup. It's worked fine with black, I guess because black can never be too black. When it comes to the brown you say you never dilute the Pro Oil. Others have said they always dilute them. It may just be a matter of finding the right process for the leather I happen to have.
For all of this to make more sense, here is a photo and description of everything I have going on for this holster.
1. 1 coat of Pro Oil light brown, dipped in water
2. 2 coats of Pro Oil light brown, dipped in water
3. 3 coats of Pro Oil light brown, dipped in water
4. No dye. 3 coats of neatsfoot oil.
5. 1 coat of Pro Oil light brown, not dipped in water
6. 1 coat of new EcoFlo light brown water stain
7. Natural leather before any dye/oil
My local Tandy manager (great guy and very helpful!) gave me a bottle of this new EcoFlo Water Stain to experiment with. He has not made a holster with it so he didn't know how the color would react to being dipped in water. I haven't gotten that far yet but the color seems to look a bit flat. It's got quite a bit of red in it too. Seems like you cover up the appearance of the grain in the leather with the water stain.
The more I look at these colors, the more I like the neatsfoot oil coloring. I would like it to be a little darker though. Apparently, putting it out in the sun after applying the oil will darken it. That would be great if it weren't overcast and raining here for the next few days. I'm on a bit of a time crunch. This may be a dumb question, but if you go with the neatsfoot oil coloring, do you apply the oil before or after molding?
The only thing I haven't done yet is diluting the dye with denatured alcohol and seeing what the water does to that. I wish I had time and budget to get in some Wicket & Craig leather but I'm afraid I'm going to have to figure out how to make it work with what I have.
post-12836-089894500 1323747063_thumb.jp
I oil after forming/baking. You might try the block dyeing method. Take a wood block, wrap a tshirt around the edge, drizzle the dye on the edge, blot the excess on a paper towel, then drag it over the surface multiple times until you get your desired intensity, but remember it will darken after oiling. You only want to use a single coat of neetsfoot oil on holsters.
Will more than 1 coat of neatsfoot end up soaking through to the flesh side?
I only use Fiebings Pro oil dyes. I dye my pieces with a foam brush before stitching. After assembly I wet mold, bake, oil, and then finish with Resolene. It sounds like Particle may be right, that your leather is too dry and it's soaking up lots of dye and darkening. If the leather is drying completely after wet molding, it shouldn't darken dramatically.
Thanks in advance!!
Again from the old grump; Just came across a bit of information that was shown on a DIY show (totally unrelated to leather working). In it a discussion of residential water systems came up, and it was mentioned that in such systems from some years ago iron pipes were used extensively, and in many places they remain in use today. The upshot is that in such a system iron oxides form in the water and that higher concentrations of iron CAN discolor fabric --- and probably leather. I do know that while in I was in one Arizona town in the early 60s, ALL of my white stuff ended up a rusty tan color after washing. 'Taint impossible that your water has something to do with it too. Mike
You'll find differing opinions on the use of oil on gun holsters. As we all know, Bianchi is well known in the holster industry and has a fantastic tutorial DVD. In his video, he instructs you to apply multiple coats of neetsfoot oil to the holster he's teaching the viewer to build. For what it's worth, his holster is lined, so there is a barrier of contact cement between the two layers of leather, so the flesh sides are not exposed and do not directly receive the oil. He oils the inside and outside of the holster several times until it's thoroughly absorbed. He says the oil acts to seal the pores, making it more water resistant if memory serves me. I believe he also mentions the oil does not penetrate very deep because the oil essentially seals the leather. He does not specifically say this is only advisable for western style holsters (as opposed to tightly formed concealed carry rigs). I would love to know if he stands by this oil method on his concealed carry rigs, or if it only applies to his western rigs.
If you drop by Brigade Gunleather's website, they have photos giving an overview of their process. They also apply liberal amounts of oil to their holsters - concealed carry rigs included.
Then there's the crowd that strongly advises against the use of any sort of oil or heat applied to the leather.
The majority of makers here seem to lean towards a single coat of oil applied after forming/baking is a good thing, and too much oil results in a limp holster in short order. That's the method I currently subscribe too.
