Tinneal Posted December 12, 2011 Report Posted December 12, 2011 I used Fiebing's acrylic resolene over some oil dye, and it seems to have dried, but it remains sticky! I don't know if it needs more time, or if I put it on too thick? Either way, I'm hoping there's something I can do to fix it! Any suggestions? Please help! Quote Leatherwork Portfolio | Etsy Shop
dirtclod Posted December 12, 2011 Report Posted December 12, 2011 Has it dried yet ? Did you try using a hair dryer on it ? When i use resolene i put it on with a sponge. Squezee the sponge out not dry but not full either and go over what ever your using it on lighty. Generally i do two coats and the resolene has been thinned down with water. Quote I'm old enough to know that i don't know everything.
Tinneal Posted December 12, 2011 Author Report Posted December 12, 2011 Has it dried yet ? Did you try using a hair dryer on it ? When i use resolene i put it on with a sponge. Squezee the sponge out not dry but not full either and go over what ever your using it on lighty. Generally i do two coats and the resolene has been thinned down with water. I applied it straight from the bottle and with a wool dauber. Obviously not the best method, judging by your suggestion! It dried overnight and was still quite sticky this morning... I just finished using some deglazer on it, and although the finish is now a bit streaky, it's become more of a matte finish than the ragged gloss it was previously. It still doesn't look professional, but compared to what it was, I'm very happy! I was almost to the point of wanting to totally redo the project. Thank you very much for replying. I will remember your suggestion of how to apply it. What ratio do you use for mixing it with water? Quote Leatherwork Portfolio | Etsy Shop
Members radar67 Posted December 12, 2011 Members Report Posted December 12, 2011 Mix it 50/50 with water. Apply a light coat, let dry, buff, and apply a second coat if you think it needs it. Quote
Members katsass Posted December 12, 2011 Members Report Posted December 12, 2011 (edited) I used Fiebing's acrylic resolene over some oil dye, and it seems to have dried, but it remains sticky! I don't know if it needs more time, or if I put it on too thick? Either way, I'm hoping there's something I can do to fix it! Any suggestions? Please help! Hi,The old grump here again; That's precisely why I started to use my 'homemade' stuff --- that, and I ran out of Super Sheen. Used Resoline once and then heard of too many having probs with it. Believe it or don't, but I mix 'Mop and Glo' 50/50 with water --- YES the floor goop you get at the grocery store, and I mist it on with an airbrush. It can also be applied with a damp sponge, rag or even a pump sprayer ripped off from a bottle of Windex. Just apply lightly [wipe any drips which occur (because you got too close with the sprayer), with a finger, towel or shirt-tail] allow to dry (five minutes or so) apply a second LIGHT coat and you are done. Done, unless you do as I do and add a thin coat of Kiwi neutral shoe polish, buffed out to a nice sheen. (Apply the polish with your fingers only, and rub in well, then buff.) The Mop and Glo is basically the same kind of stuff as Resoline, ie. an acrylic. The M&P will set you back around $5.00 for something over 30 oz. Check the cost of resoline, Super Sheen etc. and do the math --- and you can still use the rest to do your floor with! Mike Edited December 12, 2011 by katsass Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
dirtclod Posted December 13, 2011 Report Posted December 13, 2011 Tinneal, i don't know how much water i put in. I just eye ball it. I keep mine in a tupperware type container and the sponge stays in the container. Quote I'm old enough to know that i don't know everything.
