Members Kcinnick Posted December 22, 2011 Members Report Posted December 22, 2011 Is there a black dye that won't rub off? I like dyeing belt edges black, but fiebings pro black rubs off really easy. What's the best? Angelus, Lincoln, something else? I hate putting heavy coats of clearlac on the edge to keep black from rubbing off. Quote
Members Rising Sun Leather Co Posted December 22, 2011 Members Report Posted December 22, 2011 If you are finishing the edges, after the dye has been applied, slick the edges with a slicker tool or canvas or even some old faded blue jeans. After the edges dry, apply some Gum Tragacanth to the edges. Let the gum sit there for a short time,(until it looks like it's about dry), and then slick the edges again. This will help quite a bit, then you can use a very light application of super or satin sheen on top of that and you should be good. (black is a pain in the butt to keep from rubbing off without super sheening the heck out of it) Have fun, Joey Quote www.RisingSunLeatherCo.com (702) 371-3125
Members Kcinnick Posted December 22, 2011 Author Members Report Posted December 22, 2011 If you are finishing the edges, after the dye has been applied, slick the edges with a slicker tool or canvas or even some old faded blue jeans. After the edges dry, apply some Gum Tragacanth to the edges. Let the gum sit there for a short time,(until it looks like it's about dry), and then slick the edges again. This will help quite a bit, then you can use a very light application of super or satin sheen on top of that and you should be good. (black is a pain in the butt to keep from rubbing off without super sheening the heck out of it) Have fun, Joey I can make pretty edges thanks to spinner and hidepounder. They just rub off without enough clearlac to make the pretty edges look like plastic. With hidepounders tutorial Ican make two pieces of leather look like one. I can't find a source of Lincoln dye. Should I switch to using dark brown for my brown belt edges? Will it be more colorfast? Once I am done with my drum dyed black leather I am using roon for all black. If I apply roon with a copic sketch marker, will it turn just where I put the roon or will it run into my natural liner? Thanks Quote
Members Rising Sun Leather Co Posted December 22, 2011 Members Report Posted December 22, 2011 Not sure about switching to the brown, but it is worth a try. It should be fine. Black is the only color I ever have problems with. As far as the roon goes, I can not be of any help as I am brewing my first batch as we speak. Today is the 7th day since I made the roon and so far haven't notice any change in the liquid. Must be patient. Good luck, and if you have any other questions just ask. Joey Quote www.RisingSunLeatherCo.com (702) 371-3125
Contributing Member TwinOaks Posted December 22, 2011 Contributing Member Report Posted December 22, 2011 The vinegaroon will soak into the fibers, possibly bleeding into areas you don't want it. Remember, it's not a dye, it's a liquid chemical and it's causing a reaction inside the leather. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Kcinnick Posted December 22, 2011 Author Members Report Posted December 22, 2011 So my hunt is on for the most colorfast black and best way to apply clearlac to just the edge neatly. Copic markers put it to thin, small wool daubers tend to drip. I'll get it right, and the inspiration will come from this group. Quote
Contributing Member TwinOaks Posted December 23, 2011 Contributing Member Report Posted December 23, 2011 Q-tip. Spray your clear lac into a small jar or cup, and dip the q-tip in it, then apply by wiping or rolling along the edge. You can do the same thing when you apply your dye, just press the q-tip against the side of the container to squeeze out the excess. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Kcinnick Posted December 24, 2011 Author Members Report Posted December 24, 2011 Q-tip. Spray your clear lac into a small jar or cup, and dip the q-tip in it, then apply by wiping or rolling along the edge. You can do the same thing when you apply your dye, just press the q-tip against the side of the container to squeeze out the excess. I apply edge dye with an empty copic marker. Works great. I just need a dye that won't come off. Quote
Members Kcinnick Posted December 28, 2011 Author Members Report Posted December 28, 2011 I tried whittemore black shoe dye today and hand burnished with very little dye transfer. I am going to clearlac the edge tommorow and hopefully it will seal with a couple light coats. Quote
Members ramrod Posted December 29, 2011 Members Report Posted December 29, 2011 i have found that feibings oil dye will not rub off. you might give it a try. Quote
