Is there actually a pad in it, or just the leather itself? It seems the pad would just need to be wet molded and then sewn on.
Looks like that was just a way to add a sling without adding swivels. If you put a pad in it, that will change the length of pull on the stock. That may be good,or it may not.
You laugh at me because I am different. I laugh at you because you are all the same.
Most of the designs don't have a pad in them. They are used generally to provide a little friction and keep the butt from slipping when working the action.
Yes and yes, good observation. The fellow wants a pad added to the rifle but I don't think I could/should do it through a leather mount.
The leather makes sense especially in this case where the weight of the gun is on that piece.
Think I'll tell this fellow I can't make what he's looking for. Seems more hassle than it's worth!
