I was wondering if anybody had a XDm 9mm magazine that they could give me the measurements off of?
Josh Duvall
I don't have them handy but I could get them for you tonight.
That would be perfect.
Thank you
Josh Duvall
The 16 rd. mag. is 5 1/8 long loaded and the mag. tube is 3/4" x 1 1/4" and the base plate is 1 5/8" . 10 rd. mag. is 4 1/4" loaded. Note the newer XD 9's are using bigger mags. and they may be double stacked so would be worth your time to ck. a local gun shop to verify the dim. didn't change too much. Altho to be honest I put a Tandy kit mag. carrier together and both those mags. fit fine along with a 13 rd. 45 cal. mag. so the basic dim. will fit a lot of guns. If you are not using a retainer you may want to use a welt inside for tightness. Good luck.
