hoping someone can print this out "actual size" and tell me if the grid is still at one inch,
and/or maybe print it "to fit page" (letter, 8.5x11) and check if grid is still one inch
thanks
Negative! When printed out, the grid is @ 3/4" ...
I've taken the liberty of resizing the drawing to fit your scale... Hope you don't mind ....
Edited by TroyS
Well, that sucks! I know the drawing I attached is correct in size so I'll assume the drawing you submitted is correct in size Hammerhead because the same thing happened. It reduced the pattern to 3/4" scale .... weird! Gonna have to investigate this more ....
if you right click and click print it prints smaller, try right click ,save picture, then print from your downloaded and i think it will print to the right size
I'll try a pdf file, maybe thats the way to go
bic_holster.pdf
It scaled at 1".
Crystal
Yeah, if ya save then print, everything is fine! Thanks for the pattern!
that pdf file prints out right on the money
The pdf print out works fine. Thank you for the pattern. The 3/4" one might work for the mini bic lighters.
Tom
