If you are making the walls of the circle and lines 1/16 inch wide use Pvc or the
conduit that has walls about that thick as a tool. The connecting lines cut however
width you want out of the tubing. Connecting lines a flat-headed screwdriver or
chisel ground down to 1/16 width. depending the distance between the circles
the chisel would make a longer impression.
Joe
