Kingswarrior
Tanning Snake Skins
After looking at some previous posts, I was wondering if the tanning process for rattlesnakes would work on basically any snake skin? How long of a process is it to tan one? I am limited on space, and the smell would be a factor. How much space do I really need and how bad is the smell? Is there a particular kit that stands out or do you prefer the acetone, alcohol and glycerin mixture? Thanks for your help and time.
This would be good stuff.
http://www.vandykestaxidermy.com/VRT4-P3860.aspx
The skin itself with the tan on won't smell.
http://www.vandykest...VRT4-P3860.aspx
Thanks Tree Reaper. The process seems simple enough with their instructions. What about the smell of the solution itself? Will a box fan in a window be adequate for air flow and ventilation when using this?
I don't think there will be any smell to it.
I have used that specifically but anything else I've used to date for tanning hasn't been strong smelling.
Many thanks.
