I have an order for an XDM .45 compact (3.8in barrel) and I was wondering if I could use my XDM .40 comapct to mold the holster?
They appear to be the same size, but i know that some .45 models are slightly larger than their 9mm or .40sw counterparts.
Any thoughts or experience with these guns?
Thanks!
The .45 XDm is larger in size. If you pattern and mold the holster for a .40 version, it will be a VERY tight fit, if you can get the .45 in to begin with... Most of the difference between the two is in thickness of the frame and slide... Not a huge difference, but considerable enough, if you sew tight lines and wet mold with detail.
-Good luck. Let us know which direction you go and how it turns out.
-Tac
-Tac
Thanks for the info Tac!
I already have the blue gun for the 9mm/.40 Xdm so I'm going to give it a shot with that. I will be sure to leave a bit of extra space on the stich lines and not go too crazy on the molding. HOPEFULLY that works... I know of one way to find out :)
If it doesn't work I'll be sure to let you know.
