pavilionpony Report post Posted July 8, 2008 I seem to be running into a snag as far as what the proper oz. weight is to use for a western bridle. What weight do you use (if you make bridles) and why? Quote Share this post Link to post Share on other sites
pella Report post Posted July 8, 2008 english work i go with about 10oz but i preffer to go heavier with western headstall, especially if it is not lined, about 13oz. But you need to skive buckle return even under the buckle not to have a big blob and to be able to buckle properly. Quote Share this post Link to post Share on other sites
pavilionpony Report post Posted July 9, 2008 Thank you pella, I have one I started with 8-9oz. and wondered if it would be ok. It seems heavy enough, but I wasnt sure how heavy I could go. Thanks for the reply .Ah yes the skiving. I had to do that even with the 8-9 oz. Cut my finger tonight ; seems I do that alot! Better lay off the during work hours....lol. Quote Share this post Link to post Share on other sites
pella Report post Posted July 9, 2008 8-9oz (and if it is on the 8oz side) will not last as long, were bit is attached, you can maybe line this part. Keep your blade very sharp...thats will prevent cut fingers ! For reins, 8-9oz is thin too. But if you use the best part of hide, and put lining on bit attachment, that may help... Quote Share this post Link to post Share on other sites
