Are sprays not that good? I'm thinking they would be much less messy
Compare spraying paint and applying paint by brush. The brush method would have more control. Same with glue. Of course, if you find that you can control a spray better....
Quick question, do I want to be cutting on the grain (outer) or the inner side of the leather?
I cut on the grain, because I mark my cut lines on the grain side with a scratch awl. The flesh side doesn't take markings very well. Also, I cut from the grain side so that I can avoid any natural blemishes if any.
Thanks, make sense
I've got all my cutting done, with some leather left over for practising.
I'm not sure which bit to do next.
I'm never going to be able to cut the flaps to match exactly when folded over, so I'm thinking I should glue, sand and then do the stitch crease or grove. Make sense?
I've done the glueing and the passport fits in okay.
It wants to pull the the case open. I've not creased or grooved the center fold yet, is that likely to work? Am I better just putting a book over it for a few days?
post-30018-085923800 1340135229_thumb.jp
For center folds, it is not necessary to groove it. We groove only for sharp corner folds. Your idea of a book over it should work just fine.
I myself would lightly damp the center fold, fold and align the corners perfectly, then hold them with wooden clothes peg.
