Yeah, I think corners are a whole different story. I haven't been able to afford a round knife yet, so maybe at that point my technique will change drastically.
For me, the best sander is a piece of sand paper in my hand, but again, that's because I'm pretty cheap for the time being until I start getting some cash flow.
I second some of these replies....get a good round or head knife and learn how to use it!! Not hard if you try...been doing my cuts up to 15oz for many years with a shoe makers blade...works great!
Then I made a commitment that if I call myself a leather worker I will use a traditional knife to cut....a round knife!! And guess what, I love it and it is the only knife I use for 90% of my work!!
Keep it extremly sharp, learn how to sharpen any knife in ur shop.....then use it like a pinstriper would do...( I dabble a bit in pinstriping..) look ahead of the actual cut...feel where u cut and get used to the "slide" when cutting ...so you wont over cut or put to much pressure on the tip....practice, practice and then some more...!
A good blade has good steel, u will know the difference when sharpen and when u cut....good knives dont come cheap, but your grandkids will fight over them...haha...
A good used older brandname head knife can be found at leather shop sales, ebay and sometimes at estate sales.
Lets go cut some leather....
Aloha
http://www.elfwood.com/~alien883
First it is just leather....then it is what-ever I can dream off...
I cut out my pieces 1/4 inch or so oversized. I case the leather (not soggy, just cased throughout). I then trace the exact shape and cut it out. A polished Hyde knife goes through cased leather like butter.
Diapers and Politicians should be changed often...
Both for the same reason!
  • 2 months later...
I'm partial to a rotary cutter and a good straight edge myself. Stand up and cut confidently = nice clean cuts.
X2 on the round knife and also on dampening the leather, I haven't tried it with the leather competely cased but dampened it tends cut smoother. Use the tip of the round knife for going around curves and a little more blade when going straight. One thing I do and I'm not sure others would agree but here goes. If I have lots of tight curves and a little more intricate cuts I precut them with a swivel knife, that provides a nice guide to follow with the round knife and for lack of a better term chamfers the edge and gives it a more finished look even before sanding and burnishing. Just my way of doing it, may not be the recommended way.
:deadsubject:
Ken
"Life's too short to carry ugly leather"
Haven't used a round knife before myself. I use a cheap utility knife (with neon green plastic body *gasp*) But I only work with 6-7 oz max.
1. I use the smallest size knife, those used for craft paper. The small size tip is easier to go round corners.
2. I break off dull blade tips often. They are too cheap to bother with stropping.
3. I stand up, and try to keep my knife straight up. I also give it 2-3 passes if thick.
4. The thing I keep in mind most is, when my project has a round corner, I do not cut a rectangle, then round the corners. I cut the straight lines with the aid of a metal ruler, stop before the corner, then go a little more and when reaching the corner, I turn the leather while keeping my knife straight up and almost stationary. I found it impossible to get a nice corner when manipulating the knife as the wrist is a limitation. I manipulate the leather through the knife. With this, I found round corners a breeze. Especially with a cutting mat below.
5. I don't think I am alone in doing this. 0.34 of the video
Edit: I'm not saying a round knife is not the answer as I haven't tried it myself. But since you already have a utility knife, and you've got the leather, it's easy to just try this out and see if it improves your cuts while you decide on a better cutting tool.
Edited by reddevil76
