FHL FERG Report post Posted May 19, 2012 Hello all, I have a "new to me" cobra class 4. It is amazing to work with! I have been adjusting things and trying to get it all dialed in. I have noticed it occasionally skips a stitch. Since I am new to machine sewing I'm not sure whats wrong. Is it me trying to move too fast? Does the machine need a timing adjustment? or maybe the thread needs a tension adjustment? Thnaks Ferg Quote Share this post Link to post Share on other sites
dirtclod Report post Posted May 19, 2012 Was it sewing fine before you started adjusting ? I would check and make sure it's threaded right and that the bobbin is in right. Then put a new needle in and see what happens. Quote Share this post Link to post Share on other sites
FHL FERG Report post Posted May 20, 2012 It was disassembled to be moved. I reassembled and started sewing. When I said "adjusting" things it should have been assembling and threading. It is threaded correctly according to steve's video that came with it and the bobbin is correct. I was thinking it may be the needle or a thread tension adjustment. Quote Share this post Link to post Share on other sites
