So, I had a friend that loved to play cards. By Christmas, I didn't have anything for him. That made me feel terrible, so I built him a playing card holder. Now, he can bring his cards with him any wear, without filling up his pockets. Here's how it is built. This does involve casing the leather, so for a more in-depth tutorial, follow My link.
First, find a deck of playing cards. These were my friends, so I borrowed them to build this.
post-17704-073136000 1338229923_thumb.jp
Next, I built a duct tape case for the cards, so they would not get water damage during the casing process. Duck tape can be a pain, and my way may be different from yours.
post-17704-010411700 1338229838_thumb.jp
After building your waterproof case, find a plank of wood about the same thickness of the deck. Mine was 3/4 inch thick.
When you find the plank that you need, grab your leather. The leather should be light, but not to light. Unfortunately, I forgot what weight the leather was. You should need about 15 inches of leather, and it must be 4 inches wide, so you know you have enough. I prefer to have a large comfort zone with my leather, so the piece I used was 9*6, as well as a 3*5 rectangle for the back, and several 1*5 straps.
Snaps and a snap setter are necessary, as well as a needle and thread. Hole punchers help with the snaps, and also the stitching. There is enough space on the leather to do some tooling, so tools could be used on the leather. Dyes make the leather look better, so I used black.
So, to start with, you will need to take your cards, put them in the duct tape case, and case the leather. Take the deck, place it on the plank, and lay the large leather piece over it, with the top of the deck peeking out.
Now, use some water and a cloth to make the leather wet. Stretch the leather over the deck, and use finishing nails to secure it. This will take lots of nails. Use a tool of some kind, I used a butter knife, to push out the air pockets. Moisten the leather, and let the leather sit, keeping the leather moist. This will take about half an hour, once assembled.
*Since I have limited time today, I will not post pictures of the rest of the process.*
Now, remove the nails. Use an xacto knife to cut off the leather with nail holes in it. Furthermore, make sure that the leather has a flat base.
Take the small leather rectangle, and stitch that onto the back of the cased piece. You should now have a pocket, snug when the cards and duct tape case are fit inside.
Once all of that is complete, we will atatch a belt loop onto the back. The belt loop should not go past the cards. W will also atatch 2 straps that go over the cards, with snaps set on the ends. Attach snaps to the cased leather. To assist in punching holes, use a saw, and cut a small piece of wood the size of your deck from the plank.
Once you are finished, make it yours by tooling the front, and dying the leather.
Here are the other pictures in order.
post-17704-045157600 1338230083_thumb.jp
post-17704-070870400 1338230098_thumb.jp
And more..
post-17704-046508900 1338230169_thumb.jp
post-17704-019960200 1338230182_thumb.jp
Last one..
post-17704-052267000 1338230231_thumb.jp
