I recently picked up an old Dixon plough Gauge on a local auction site for a pretty good price and when I got it I found its rather unlike either of the ones I have at the moment. The main difference is that the height of the roller is adjusted solely by a screw, there's no secondary fixture to hold it in place once it's height adjusted.
The blade is the most interesting bit though. Instead of there being a milled slot in the blade there is a piece that has appears to have been forge welded from two parts, leaving a slot for the blade, and then riveted in place.
post-13283-065037600 1339411406_thumb.jp post-13283-010169100 1339411409_thumb.jp post-13283-004957500 1339411411_thumb.jp post-13283-007900500 1339411413_thumb.jp
I'm wondering whether the blade has been repaired by an enterprising owner at some point in the past or whether this is a really early way of making the slot. It would surprise me if this was a normal way of doing it since it's rather a labour intensive way of doing the job and I'd be surprised if the blade predates the use of a mill to cut the slot. If it's a repair, it's really rather well done.
It looks to me that someone has made a repair with an arc welder, and "forgot" to grind off the surplus metal from the weld. A nice auction find!
/ Knut
Edited by oldtimer
1339421561[/url]' post='252099']
/ Knut
It's definitely not machine welded, the pictures might be hard to make out but in hand it is clearly a separate piece that is riveted in place on the blade.
I Knut is right, it is repaired. Here is my J. Dixon plouge with a T. Dixon blade. It is a common issue with all old plouge knifes.
Trox
post-10237-038528500 1339470223_thumb.jp
post-10237-031833300 1339470228_thumb.jp
