Rods from home depot or Lowes. Epoxy is JB Weld. Virtually any two part epoxy should work as there isn't much stress on the part.
Sorry Steve one more question. When you first draw your templete around the gun am I correct in that the rod is on the gun ? Or do you take the rod of when making templets? Seems like it would need to be on the gun to make room but want to check. Muck thanks
I do not take the rod into account when making a template, but I like to have a really tight holster.
I cut 1/4" off the end of a Commander length blue gun. Works like a champ! I did the same thing with a 5" Operator blue gun. Cut 1" off the end and reworked the end of the rail and dust cover area with a dremel to make a 4" railed dummy. The good thing about blue guns is that you can rework them pretty easily.
I did the same thing with a Commander model to get a 4" model.... as Steven said, works like a champ....
www.kolbesonleatherworks.com
www.shopleatherworks.com
www.facebook.com/kolbesonleatherworks
