post-29226-011263300 1342532971_thumb.jpJust trying to perfect a pattern and was wondering if this looks ok or if I should move the stitch line closer. Any thoughts or critizism are welcome. S&W
J frame, horsehide and Barbour's 7 cord.
Thanks
Jeremy
Edited by J Hayes
For visual consistency I'd tighten up the middle section, and a little bit along the barrel. Retention is most paramount, followed by aesthetics. At least that's what I have learned from this forum and elsewhere. I've been studying lots of websites for just this sort of thing. You can find website links on people's posts here in the holster section of the forum.
Jake
Edited by SooperJake
Thanks
Jeremy
From the old grump: Seems to be OK along the top strap but needs to contour more around the trigger guard and especially at the front of the frame. As it sits, I would expect to see the gun start to sag on down into the holster as far as the frame will go toward the existing stitch line. Mike.
Think this will be to tight? post-29226-029267100 1342615730_thumb.jp
i noticed the t nuts on this...is it going to be an inside the waist band?...if so, i think i might keep it loose...too snug, add a belt, and it aint coming out...if its a snap on, your gonna have to stretch it real good to get it in...
Yes it is an IWB, hopefully it won't be too tight, but I'll have to stitch it to find out. Kinda wish I had a machine just to do patterns, I'm not real fast at hand stitching. Revolvers are a PIA
Jeremy
Jeremy
have you considered just making it a pouch type?...i too wish i had a machine for pattern holsters...thats where most of my production time goes, getting it right..
My personal carry rig is almost identical to the posted one, it holds pretty good but I do wish it was a bit tighter. I guess I'm chasing perfection, I'll never catch it but I can make it look better than it does. I want to mimic the lines closely, and I like to bone the detail in, even though nobody sees it.
The ones I've done for a G23 and 1911 Commander were much easier to get the lines tight, all IWB.
Jeremy
post-29226-089117800 1342841057_thumb.jp
What's the verdict?
Jeremy
