ItsJustNC
A Belly Big Problem.
Hey guys, I've always been more partial to items that are built with a more rigid construction, so i often find my scrap bin full of belly hides. Not wanting to waste them, i was wondering, what are some of the things that you guys make out of them...?
I use bellies at 4/5 oz for checkbook covers, wallets, money clips (Magnetic), Bible Covers, etc. I only use Hermann Oak but it gives the item a better hand and feel than stiffer leather (My Opinion).
with 5/6 oz I make guitar, banjo, dobro and mandolin straps same reason, they really drape well feel good on the shoulder, etc. Can also use them for knife sheaths, phone cases, ipad covers, etc.
You can use either one for belts by laminating them back to back to make them into 8/10 oz or 10/12 oz pieces then stripping them out to 1-1/2" if they're long enough.
Try some it's better than just leaving it around and throwing it away. The list is pretty long of what you can do with them.
Ken
Sounds like a plan Ken, thank you for your suggestions.! I should try lining ti and double plying it to reduce the stretchiness..!
Other suggestions still welcomed..! Some pictures would be perfect.! Would love to see what are some of the other things you guys do..!
Bellys are good for anything that needs to be wet formed, because the structure of the skin s not as denser than on shoulder or back, hence it stretches better over a form. Wet formed zippo holders can be made out of small pieces.
Greetingsjonathan
Hmmm.... Great point Johnathan.! I see a lot of wet molded knife sheaths and lighter cases planned for my bellies next time.! Thanks a lot for your suggestion.!
In the heavier weights ie: 8/9 and 9/10 they are great for butt stock shell holders.
