Sorry about that - I misinterpreted your previous post, thinking you use gum trag OR 50/50 mop & glow. Don't give up on the gum trag - just use it after you dye your pieces. I use it at the very end, right before I apply my final sealer. For my airbrush, I'm using an old Badger 150. You should be able to spray anything thinner than milk just fine - is your airbrush just spitting the liquid out, or not spraying with a very heavy flow? I have to tear mine apart completely every now and then and dig around inside to pull out the gummed up dye and acrylic residue. Gets clogged up after maybe 20-30 uses.
Mine just kind of spits..it will fan fine for a minute or two, then it will spit a little, then go back to fanning...i need to spend some quality time playing with it, but there are only so many hours in a day...but it was a harbor frieght special, so i think im gonna save up my play time till i get a better one...
Havoc Holsters
