Yanni Report post Posted July 26, 2012 Final question before purchase... If you had the chance between the above two machines, which one would you go for ? The Pfaff is Made in Germany where the SEIKO Made in Japan. Thanks... Quote Share this post Link to post Share on other sites
Trox Report post Posted July 26, 2012 An original Pfaff needle plate cost more than Chinese 335 clone, the pfaff are a very good machine, but the spare part prices are astronomical. You have to take that in consideration. You have to try them both if they are used machines. Final question before purchase... If you had the chance between the above two machines, which one would you go for ? The Pfaff is Made in Germany where the SEIKO Made in Japan. Thanks... Quote Share this post Link to post Share on other sites
Parfektionisto Report post Posted November 16, 2019 Hi Yanni, Which machine did you purchase in the end? Does Pfaff 335 and seiko lsc-8bv have the same specs? Meaning do they have the same capabilities? Your info or anyone with any info about this will be appreciated. Tony Quote Share this post Link to post Share on other sites
