Members cowboy bowhunter Posted July 28, 2012 Members Report Posted July 28, 2012 Does anyone have a pancake holster pattern? I have a few people asking me to make them but i cant find a good pattern. Quote
Contributing Member TwinOaks Posted July 28, 2012 Contributing Member Report Posted July 28, 2012 Look in the Pinned topics and there should be a thread that tells you how to make your own pattern. Aside from that, asking for a "revolver pattern" is kinda of like saying you need a set of tires for your car.. it's too ambiguous. While there may be some 'generic' patterns, it works best to have a pattern for each of the different types - 5 shot, 6 shot, exposed vs. hammerless, snubby, mid size barrel, long barrel...etc. Then, you need to develop patterns based on the two primary types of holster - clam shell or pancake....broken down into with or without carry strap.....and OWB vs IWB. Quote
Members cowboy bowhunter Posted July 30, 2012 Author Members Report Posted July 30, 2012 Look in the Pinned topics and there should be a thread that tells you how to make your own pattern. Aside from that, asking for a "revolver pattern" is kinda of like saying you need a set of tires for your car.. it's too ambiguous. While there may be some 'generic' patterns, it works best to have a pattern for each of the different types - 5 shot, 6 shot, exposed vs. hammerless, snubby, mid size barrel, long barrel...etc. Then, you need to develop patterns based on the two primary types of holster - clam shell or pancake....broken down into with or without carry strap.....and OWB vs IWB. Thank you. Ill have to try making my own. I have been working on the 1911 holsters still and havent had time to try a revolver pattern this weekend. Quote
Members dilligent neophyte Posted August 2, 2012 Members Report Posted August 2, 2012 P.S. revolvers using a pancake style need a little extra rooom to accommodate trigger guard because of the cylinder width - when ya squeeze them in, the opening can all of a sudden squeez down and become too small I made a pancake for a .357 and left about 1/2 " all around using 7-8 oz and it was a tight fit but it streced in and worked well. The folowing S&W .500 using 9-10 oz was not so agreeable . The almost 2"width of the cylinder/frame and less strech made my estimated 1/2"-3/4" over size on the outlline too close. I ended up making another and adding +3/4" to the trigger guard side - next time maybe a thick welt all around for heavy leather and a big gun ... live and learn... Quote
mlapaglia Posted August 3, 2012 Report Posted August 3, 2012 Standard formula is 1/2 the thickness of the widest part of the gun + the width of one layer of the leather. So a gun with a 2" cylinder would need a offset of about 1 1/4 ". If used this on a pre-27 S&W and it worked great. Quote
