TXJhawk Report post Posted August 13, 2012 I recently purchased a boss and have been working with I for a week or so. My main frustration is when I double back to start and stop my stitch line. When I do this I am it getting a big mess on the back side and it loos terrible. I am sure it's a matter of havig the proper tension but the stitches look good once I get going. Any tips on how to improve the begining and ending would be greatly appreciated. Quote Share this post Link to post Share on other sites
particle Report post Posted August 13, 2012 I got that too when I had a Boss - I found it best to rotate the piece 180 degrees and stitch a few stitches, then rotate it back around and stitch the piece. When I got to the end, I would either overstitch my previous start point (in which case, I wouldn't do what i just said - I'd just start at the beginning and go all the way around then overstitch the start point by 4 or 5 stitches), or rotate the piece 180 and overstitch 4-5 stitches. That probably made ZERO sense. Imagine two scenarios.... If I sew a straight line where the two ends do not touch one another (like they would if you sew a circle), I'd make a mark (point A) that is equal to 4-5 stitches away from my start point (point . Then, starting a point A, sew towards point B, then rotate the piece 180 and sew to the end (point C), then rotate back around and sew a 4-5 stitches and end (point D). If I sew a circle with the two ends touching, I'll simply start sewing at the start point, then go all the way around and end by stitching over my start point 4-5 stitches. Bottom line - I would never sew backwards with the Boss if I could avoid it. I have a Cobra Class 4 now, but I still do the exact same thing I just mentioned as a general rule. The stitches just look better that way. Quote Share this post Link to post Share on other sites
TwinOaks Report post Posted August 14, 2012 I do it the lazy way - I hand sew the start and stop points, using a saddle stitch (two needle), and 2.5 or 3 stitches....depending on whether the thread need to end up on the back. Quote Share this post Link to post Share on other sites
