Members renegadelizard Posted September 18, 2012 Members Report Posted September 18, 2012 Hey all, My cobra class 4 is due in tomorrow....any tips or tricks to make it easier to get up and running?... Quote Havoc Holsters
dirtclod Posted September 18, 2012 Report Posted September 18, 2012 Have somebody there to help you get the head on the stand. Their heavy. Quote I'm old enough to know that i don't know everything.
KAYAK45 Posted September 18, 2012 Report Posted September 18, 2012 First lay out all the parts on the floor. Read the directions! Dry assemble by putting the parts on the floor in close proximaty to where they go. Read the directions. Look at the pictures. You will NEED a helper to mount the head. Read the directions. Look at the pictures. Before you add the drive belt, make sure it will free wheel by hand with NO rough spots. After the belt is tensioned you will need..a little power..to free the motor for hand wheel. It probably will come with thread to the needle, cut off the spool. Do not pull it out. When ready to thread follow the old thread and put new thread from spool, one step at a time. Do not adjust the tension. Something else is wrong. It came set up. .. Adjust your pedal linkage, should be ready to screw up...I mean sew. LOL Good luck, Kevin PS: To adjust your table height after starting, please disconnect power and pedal linkage, and have a helper. Quote Once believed in GOD and the DOllAR...... Hello God!
Members Cobra Tom Posted September 18, 2012 Members Report Posted September 18, 2012 Watch the DVD. Read the manual. Take your time. Follow the setup instructions. If you have questions, call Steve! He's the man, if he can't help you no one can. 866-962-9880 Quote
Members renegadelizard Posted September 19, 2012 Author Members Report Posted September 19, 2012 On 9/18/2012 at 3:55 PM, Cobra Tom said: Watch the DVD. Read the manual. Take your time. Follow the setup instructions. If you have questions, call Steve! He's the man, if he can't help you no one can. 866-962-9880 got it all set up...no helper so i had to screw up the courage and tackle it myself...you guys are right, its heavy ...really heavy...but i got it all working..its amazing...what used to take me an hour and a half to sew took a little over twelve minutes....this thing is awesome... Quote Havoc Holsters
Members Massive Posted September 23, 2012 Members Report Posted September 23, 2012 I had to use a winch to raise my machine onto the second floor. Never lift anything truly heavy if I can avoid it. Quote
Members renegadelizard Posted September 28, 2012 Author Members Report Posted September 28, 2012 Hey All...how hard is it to attach the strap good plate?...and how do you remove the feed dog...i cant seem to find those answers in the manual...also, when i put the other plate back on, do i have to readjust anything?....vieos would be great at this point.. Quote Havoc Holsters
