rmr
Size Of Thread To Use On A Saddle?
Im currently making ( or trying to make) a saddle for my daughter. Lookat at the Jerimiah Watt dvd about 10 times, and read every book I can find on it. So far going ok.
Im now at the point where I need to do some sewing- skirts and cantle back. I cant find any referrence on the weight of thread to use. On most of my other leather work ( shotgun cases and flyrod cases) I have used 277 size thread. Im guessing that is too thin to use on a saddle?????
If so would it be best to get 346 or 415 size thead?
Thank you for any advice
RMR
Normally I use 277 on top and 207 on the bottom. This is how I was taught and has worked just fine on all the saddles I have built. The only thing I did different then taught was to go up one size in needles to keep from cutting the thread on back stitches.
I'm using 277 on top 346 on bottom for what it's worth on the skirts, but for the cantle and saddle horn I use hand sewing thread with an awl and parafin wax.
