Like most on here I use dummy guns rings, duncan etc. If you watch the for sale of this site you will frequently find them for less then new price. However there are times when you can't get a dummy for a certain model. I am making a holster for a person in Canada it is a holster for a Colt New Service .455 eley (no dummy found for it). There is no way for him to get the gunn to me. Yesterday I found a picture on the web found the length of the actual weapon and resized the picture to correct size. I cut it out so I had a paper pistol. Any measurments I could not get from the picture I could call the customer for. I went down to my shop found some dowel and a scrap piece of 1 x 6 pine layed the paper pistol on the 1 x 6 and cut out the pattern with a jig saw. I then drilled out a hole for the barrel (3/4") cut the dowel to the appropriate length inserted it into the hole. The cylinder is 1 3/4" I had 1 1/2" dowel cut to the right length and wrapped with duct tape to get the right diameter. In less then 30 minute using jig saw, drill and scrap found in my shop I had a dummy gun. You don't even really need the grip cut out unless you are going to build a flap holster and you don't really need the hammer unless you are going to add a retention strap. It's not pretty but it will work, this is not for a holster I will need to do a lot of detailed boning to. If it were I would just use a dremmel to ad some detailto the model. I will probably clean up the trigger area alittle not because I need to, but just because.
post-15001-0-47832400-1350061979_thumb.j
post-15001-0-48672600-1350062012_thumb.j
Edited by camano ridge
