Is there a difference when using baking soda to neutralize acid from vingaroon if the leather ist whet or dry? I ever used it immediately after the blackening process when the leather is always wet from the Vingaoon.
But can I do the neutralizing later, with a drying period between?
You might get some neutralization that way, but I've found that the process tends to push the tallow and waxes to the surface which makes wetting it again a real PITA.
Most of the time I neutralize immediately after the dip. After it's dry, I have to pretty much submerge the piece to get it wet. And presuming the next question, yes I mold while it's still damp from the 'roon process.
Mike DeLoach
Ok, thanks.
  • 2 months later...
How much Baking Soda to water for the neutralization?
Once you know what the magician know.... it isn't magic anymore.
good question Shtoink
I use an 1/8 of a cup of baking soda to a half gallon of water or thereabouts - just dunk the piece (if two big just wipe it down with a wet sponge) in the mix for a count of 5-7 seconds (DO NOT wait until it stops bubbling that will alkali burn the leather and can cause brittleness), rinse with clear cool water, apply you're favored oil/conditioner, and go from there......and yes I do not wait until after it's dry.
Two roads diverged in a wood, and I,
I took the one less traveled by,
And that has made all the difference.
Thanks Chuck
