Moderator bruce johnson Posted December 7, 2012 Moderator Report Posted December 7, 2012 I guess I apply it differently. I have been using a paint roller for years. Fine napped paint roller and plastic tray. I can control how heavy I apply it by how much I roll out on the ramp before I got to leather. I get a good even coat all the way to the end on belts by running the roller a bit diagonally. On the big surfaces I slightly overlap. I don't end up with swirl marks or spend a lot of time applying. If I have 3 or 4 small pieces like checkbooks I just line them on the table and roll over them all in a pass. Two passes on a stirrup leather will do what I need. It is a time saver for me and does the best job of anything else I have tried. For my lining sides I can do a whole side in about 5 minutes. For molded cases I use a woolskin patch and dip into my oil tray, then squeeze it out to leave what I want in it. I lightly slather it on. I leave my oil set for 24 hours after I apply before I decide if I want more. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members shtoink Posted December 11, 2012 Members Report Posted December 11, 2012 Well, so as to not sound insane, I found the post I referenced earlier from someone here who uses an airbrush to apply the neatsfoot oil. Here it is... I guess the main point is that there isn't really a wrong way to apply it as long as it isn't overdone. Quote
mlapaglia Posted December 22, 2012 Report Posted December 22, 2012 Its not a good finish but its a great natural looking dye. Not really a dye but it will darken it to that nice undyed leather look. Leave it out in the sun for several hours and it will give you a rich light brown look. Sun tanned leather. Then give it a coat of leather balm with atom wax and you are set. I love the look. Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members footrat Posted January 29, 2013 Members Report Posted January 29, 2013 I use whatever fits the size of the piece. Small straps, I use a dauber, and squeeze most of the oil back out first, then use t-shirt scraps to buff the excess off. Same procedure for larger pieces, but I might use something larger like t-shirt or underwear scraps, or a wool scrap. Again, buffing off the excess. In this manner, I can apply just a little at a time, wait for it to soak in, and see if it needs more. Recently, I had some straps that were so dry after dying that they were ashy in patches. I gobbed the oil on with a dauber, let it soak in, and repeated until the straps wouldn't soak in the oil very quickly. At at that point, I buffed them and let them sit until the surface was dry, then finished with Saddle Lac. Quote
