Contributing Member TwinOaks Posted August 12, 2008 Contributing Member Report Posted August 12, 2008 Seeing how you've constructed those, I have to wonder if you should be using 'pull the dot' snaps in place of line 24s. (presuming, of course, that you used L 24s on the mock up) Dependent on the snugness of the pouch, you might end snatching the whole thing off your belt in a real world scenario. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Shorts Posted August 12, 2008 Author Members Report Posted August 12, 2008 Thanks Jordan. I have tossed around the idea of using a stitch in the center instead. The main reason for using a tension screw is it's pretty easy and keeps the stitching to a bare minimum. Mike good eye. The cap is from a line 24 snap. The hardware underneath are the hard action DOTs. Someone forgot to order to the caps when she ordered everything else I'm also thinking of opening up the back flap in the center to form 2 flaps or at least cut a nice window between them. I think it would look better. But I do like the stability that one solid piece provides. Quote
Members BOOMSTICKHolsters Posted August 13, 2008 Members Report Posted August 13, 2008 I would go ahead and add the slot between the two snaps, for the sake of belt placement. Some folks like to postition their mag holders over their belt loops so they don't go anywhere. Quote
Members Shorts Posted August 13, 2008 Author Members Report Posted August 13, 2008 I would go ahead and add the slot between the two snaps, for the sake of belt placement. Some folks like to postition their mag holders over their belt loops so they don't go anywhere. Good call Jeff. My husband also mentioned the same thing unsolicited. And when I was trying it on, the position I wanted it to sit was immediately centered on a belt loop of my jeans. So, three confirms on the slot right off the bat Quote
