I have been using a 3-4 mm veg tanned leather, I wrap it around a mold then a few minutes after dipping in boiling in water I remove them (otherwise they get a little hard to take off) then I treat in a variety of different ways, for me it is all experimental, of the vases I show here the darker one is dyed using a water based leather dye, they are both finished with leathe balm with atom wax. the basket is finished on the inside with a leather edge paint because I did not like the look of dye on the back of the leather and it is what I had on hand, not sure it is the right thing to be using if some one has a suggestion on a better finish I would love to know. the other vase is not water proof,
I wonder if brewer's pitch would seal it.
Very nice indeed. Keep up the great work
Doug, that sounds interesting,where would one find brewers pitch?
Hi Costumeclaire. Nice vases!
I just wanted to comment on he fact that you put the leather in boiling water. Since I've made a few pieces of armor using "cuir bouilli"/ "boiled leather" as well I did some research on the larp costume making forums and got the following info:
  • the "boiled leather" name doesn't actually come from the fact that you boil the leather, but from the fact that tiny air bubbles leak out of it when you immerse it in water, creating the effect of boiling, even in cold water
  • the hotter the water in which you put the leather, the harder it'll be when dry but also the more brittle.
  • For armour I/larpers usually use warm tap water and have water of about 40°C (104°F) and leave the leather in the water until all the bubbles are gone. When it's put into shape and left to dry it stays in the same shape and is still pretty supple (meaning It can be bent to work it without breaking it and it goes back into shape once released).
Just my 0.02€.
