Members billymac814 Posted January 11, 2013 Members Report Posted January 11, 2013 The weavers press is pretty small. Harbor freight has their 12 ton press on sale for 99.00 and you can get the plates and cutting pad from weavers for another 80.00 or one could get by with two thick steel plates and a poly cutting board and do it for less money. I just cut the ram rod off of mine and secured the top plate to the bar that comes down so it also goes back up, one could just lay the top plate on top of the die. Quote www.mccabescustomleather.com
Moderator Art Posted January 11, 2013 Moderator Report Posted January 11, 2013 It Depends a lot on what your desired production capability and capacity will be. I have a harbor freight type (might be a northern or Enco) bottle jack press that was my first clicker arrangement, also good for pressing holsters. The problem with it is that it is so darned slow. There is no way to do serious production with it. I installed an air drive jack but still, not near what I desired. The manual type presses by Weaver etc. are ok for small stuff, less than 12 inches across, but the first thing you will build is an extension pole for the handle. Serious grunt power required. I ultimately ended up with the Cobra 10-Ton Clicker and it works just fine. Art Quote For heaven's sakes pilgrim, make yourself a strop!
Members billymac814 Posted January 11, 2013 Members Report Posted January 11, 2013 Art is right, a shop press conversion is no good for big production but for lower volume shops it will be much faster than cutting by hand. I normally do make 30-40 holsters at a time and can cut out the 60-80 pieces in about 20 -30 minutes without rushing around. I could probably do that in 5 -10 minutes with a real clicker but compared to hand cutting I'm ok with the 20 minutes. I also calculate in the time I used to spend touching up edges on the sander. I have an air jack on mine and I only let it up enough to pull the die out so it doesn't have far to go back down. There's a serious jump in price from a cheap shop press to a clicker press and while not perfect, a shop press does work and gets you clicking for far less money and for a lot of holster makers we already have the press anyway. I definitely at some point buy a real one though some day but I have a few other priorities ahead of that. I think the biggest downfall for me is the presses are too narrow so I can't just stick a side through it, I need to cut pieces that'll fit in. Even with all the shortcomings though it was the best thing I ever did to cut down time next to buying a sewing machine. This situation is similar to when you're handsewing and then buy a Boss you're super thrilled at how fast an easy you can now sew, then after using that for a few years you buy a 441 or something and suddenly you look back at the Boss and think how slow and inefficient it is and maybe that is true but the boss would still stitch circles around two needles and an awl. Quote www.mccabescustomleather.com
Members billymac814 Posted January 11, 2013 Members Report Posted January 11, 2013 I just checked out that cobra clicker. Its very nice and priced very good. That may be on my short list. I'm working towards the Cobra finisher right now so I can rearrange my shop and make more room. Even with the relatively inexpensive clicker press the difference from about 200 to 3200 is huge for someone who wants to start out clicking. Quote www.mccabescustomleather.com
Members Samuel Posted January 27, 2013 Members Report Posted January 27, 2013 (edited) Thanks everybody, a lot to mull over. I actually currently use cnc laser to cut/engrave (long story), but don't like the charring, and would like to adopt a more traditional means of production. I did however successfully cut/engrave some embossing stamps from acrylic today via laser. The weaver clicker is tempting... though I'm currently in a place where a grand is hard to part with. The shop press route is tempting but also seems cumbersome. And to Art, I'm in Portland Oregon, and for as much production and industry we thankfully have around here, there is a lack of accessible presses. jtron5, I'm originally from Oregon as well. I saw your post when I was doing a search on the forum for laser engraving. If you see my previous post (leatherworker.net/forum/index.php?showtopic=41796), I have access to a CNC engraver as well and I had the same problems as well. I use a hydraulic 12-ton arbor press I converted into a clicker. I learned how to weld a few days ago and I now know how to make my own clicker dies, and how to re-enforce clicker dies. It's easier than you think. If you have access to a laser engraver and want to make stamps, use Delrin and not acrylic. Delrin is way stronger than acrylic and is easier to work with on a laser engraver. Also, there should be a feature on your laser engraver that has a stamping mode, where you can get better results for creating an object for stamping. By using stamping mode, it creates letters in a pyramid shape so there is a better impression. Hit me up if you have any questions, as I'm always willing to help out - especially a former Oregonian. P.S. - GO DUCKS! Edited January 27, 2013 by Samuel Quote Stay safe and take care!
Members Slow Learner Posted June 28, 2013 Members Report Posted June 28, 2013 I just started making my own dies (steel rule dies w/plywood in the center) and I modified a 12 ton shop press. I used the plates weavers sells with their cutting pad and replaced the bottle jack with an air powered one. I have about 300 bucks invested in it and another 500 or so in the bender for the dies and some dies for it. My patterns are roughly 7" X5" and it takes a considerable amount of force to cut through 7-7.5 oz leather. I doubt that machine would do it but its hard to tell how big it is. The biggest downfall to the shop press is you need to have pieces that fit in between the arms. Some day ill get a real clicker press but for now this works better than any round knife I've ever used. I am wanting to start making my dies. Can you put up pictures of your die operation. I am wanting to do my dies as well but am flying in the dark. I am spending money on some things I may not need. Any advice would be treasured. Thanks Darrel Quote
