Members SMSRods Posted February 16, 2013 Members Report Posted February 16, 2013 Hello, I am trying to split the end of a strap about 3/4" deep to stitch a length of webbing between the two layers of leather. I've done a few by hand with a razor blade, I was hoping someone might have a suggestion to make this a bit easier. Here is what I am trying to accomplish. Regards, Scott Sheets Quote
electrathon Posted February 16, 2013 Report Posted February 16, 2013 I have an indirect answer. I would use two pieces of thin leather and glue them flesh to flesh side. Sew around them. You will have two finished sides this way. Quote
mlapaglia Posted February 16, 2013 Report Posted February 16, 2013 +1 on that idea. Gives you a professional look to the strap end. Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members billymac814 Posted February 16, 2013 Members Report Posted February 16, 2013 (edited) I'd do this too. If for some reason I would choose to split it that way I'd run it through my crank splitter an inch or so and back it back out. If that's not a possibility I'd use a round knife but you'd have to be careful because you'll pretty much have to cut right towards your hand. On 2/16/2013 at 4:09 AM, electrathon said: I have an indirect answer. I would use two pieces of thin leather and glue them flesh to flesh side. Sew around them. You will have two finished sides this way. Edited February 16, 2013 by billymac814 Quote www.mccabescustomleather.com
Dangerous Beans Posted February 16, 2013 Report Posted February 16, 2013 Again... Two pieces of leather, but don't forget to taper and glue the end of the webbing so you don't get any fluff sticking out of the sides. Nige Quote The secret to creativity is knowing how to hide your sources. www.armitageleather.com
Members SMSRods Posted February 16, 2013 Author Members Report Posted February 16, 2013 Thank you for the suggestion. Two layers does sound much better. Any suggestion on the minimum oz. leather I can get away with? These are for suspenders, will I need to stitch around the buttonhole as well? Quote
