+1 on the eco-flo pro line. Much better than the rest of tandy's dye/stain line, easy to work with on my dining room table without having to worry about ventilation or clean up, and by far the best black dye I've used so far.
  • Replies 25
  • Created
  • Last Reply
Top Posters In This Topic
dI use mainly Angelus Dyes they work well for me. If the Hi-Liter is water based then more than likely that's why it came off, especially if you didn't allow enough time for it to dry. AS Coloring Leather is a great book for dyes, and acrylic dyes and I was wondering if anyone has tried dyeing their piece brown or blue before using the USMC black to get less rub off?
Oh one more thing, Neatsfoot oil darkens leather, like really dark if you put too much on. So if you don't mind your dye job being dark then use it, but I use Lexol because it doesn't darken the leather, before and after dyeing.
Edited by prc77ro
I'm a total noob here, so take this with a grain of salt, but I used the USMC black recently in an experiment mixed with Lexol. First quick coat was raw USMC black just to get full coverage. Second coat was Lexol/USMC mixed well together (about 10 drops Lexol plus 5 drops USMC). Daubered it on right on top of the first coat. Let is soak in for 10-15 min and a quick buff and after the initial buff there is no black coming off, great looking black too.
Terry Lee
Mad scientist, general nerd, mountain man
Creator of Wonder Pickle, new Augmented Reality Comic http://www.wonderpickle.com
Newb and my input here is only about ten cuff bracelets worth of experience. Feibings has a spirit based application and an oil based application. I have not yet used their oil based but have read that many prefer it over the alcohol/spirit based dye.
Slight correction here. BOTH Fiebing's dyes are alcohol based. The "Pro Oil" is an alcohol based dye designed for use with oiled leathers. Rub it with some light oil before you dye (or after) and you're set.
I just realized that the other day. Thanks for the heads up man, still learning here. Started oiling right after I dye and have not tried to oil before. Experiencing all of this has me wanting to try vinegroon for black. Gonna give that a go here soon.
I've never tried it, but mostly because nearly EVERYTHING I do is multi-color to some degree. For black, I use the regular Pro-Oil and not the USMC. I've never used it myself, but I've heard of nothing but problems from people who do use it.
