kayrunp
When To Send The Hide Back
I got a natural carving hide that has the pattern of the shelving on the flesh side. It's sort of a honeycomb pattern. Is That an acceptable reason for a return? I am not dying it so this pattern is a problem.
It would be a problem for me. I'd send it back!
I'd send it back.
to be a little more objective, normally I would say it depends on what grade you ordered. If I order C, craftsman, budget, mystery, or whatever you want to call it, I may just say "screw it, that's the chance I took". BUT, unless you're doing something that could incorporate that design then it's completely unusable, so that's reason enough regardless because there's no way you could expect anything like that when purchasing cheaper grades.
It was suppose to be the best grade. They said no problem and are taking it back.
