Lin Cable is unwaxed but even when waxed , when i want to burn the end bits they're actually burning instead of melting as with the
threads i used .
So my question is - is there a certain method of doing it or is it supposed not be burned , but finished differently ?
Thanks in advance for the replies ,
Olivier
  • 7 months later...
Wondering the same thing...
Thanks Narvi for your reply .
It's funny because when i wrote this question in June i actually glued the Lin Cable in order to secure it but i thought that there should be something
better to do or , let's put it this way , something more secure .
So now i know i did it right without knowing .
Thanks a lot ,
Olivier
by lin thread i assume its linen n not poly or nylon ? in th old days when i was a nipper growin up in australia,we made our own thread using linen .we waxed 3 or 4 or more strands n rolled 1/2 th distance around a nail on bench.rolling down th thigh until th twis was sufficent,then holding that twist tight in other hand n rolling th other 1/2,a li'l more wax n you have a nice thread.we then 2 needled our stitch and at th end we back stitched two holes n nipped thread as close as we could.when rolling we had a square piece of firm pig lea 8x10 or so that we could belt and hang it where it cover'd thigh top.hadna done it in years i like nylon more now .
