All my books talk of nailing the leather on the horn, but my tree has a steel horn. How do I finish horn without nails?
When I was doing repairs I drilled and tapped holes, then put flat head machine screws through the filler. I ground them off flush on the bottom of the horn. An old repair guy had me paint two coats of Rustoleum primer on the steel horns to keep the rust and markings on the leather down some. Talked to a guy at Sheridan who paints them with truck body coating in a can first.
Do you also screw the wing tabs down?
My bottom covers are sewn together at the back of the neck. The wings are long enough they are hitting the back of the fork (wood). I tacked them.
Like this?
post-36557-0-93551700-1371171139_thumb.j
Harry Adams' Saddlebuilding book talks about this specifically - can't remember what it says because I've never done a metal horn, but his book is worth having.
