Members Cyberthrasher Posted June 21, 2013 Members Report Posted June 21, 2013 (edited) Next up we I take the leather with lubricated edges (from the saddle soap) over to my dremel burnisher. This makes it super quick and easy, but doing it by hand works too. I use the back channel on this one because it fits the profile of the leather better. Yes, I know, I need to clean my burnisher These next two shots are attempting to show the burnished look of it with a bad cell phone picture. Since I wasn't getting a good shot, I decided to offer some contrast and put some dye on the edge. I just splashed some dye onto my blue shop paper towel (as tom explained earlier) and rubbed it on. See how the dye pretty much stopped solid on the line? That's because the burnished edge doesn't allow it to bleed past it. I also briskly buffed it up with the dirty side of my denim scrap. Dirty as in, it's already got black streaks on it. I should also add that I really didn't take any time to make sure I had good dye coverage on it since I was just going for contrast to show in the pictures. Had this been a real project, I would have use a sponge or foam brush to get good coverage, or at least worked a touch longer on applying it with the rag. This was just a QUICK rub down. Here's our "finished" result. I have wax loaded into that denim pretty good, so I rub it in and then get a non-waxed portion of the denim to quickly rub at the edge and cause friction. This makes for a super smooth and shiny edge that you can hardly tell was once two pieces. Now, if I were putting Resolene or other finish on, I would do it before waxing. Other than that, my process is the same. As I said, this entire thing took about 5 minutes, with a lot of that stopping to take pictures over and over until I got a clear one And as far as the holes for the buckle to slide in do I do them last and just dab some dye in the carefully?? Sorry I forgot to ask earlier I usually just leave that natural and give it a quick rub with my bone folder to slick it up a little. If the customer requests that I color it, I'll brush some in there. You'll also find that Sharpie can work wonders here I don't do any texting or anything, but this method is working fine. Edited June 21, 2013 by Cyberthrasher Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Eternal Custom Designs Posted June 21, 2013 Author Members Report Posted June 21, 2013 Very cool...you can't even tell its two pieces...that's my goal...I'm gonna have to learn to stitch asap...know any good resources tri learn on a budget..lol Quote
Members Cyberthrasher Posted June 21, 2013 Members Report Posted June 21, 2013 Very cool...you can't even tell its two pieces...that's my goal...I'm gonna have to learn to stitch asap...know any good resources tri learn on a budget..lol I'm still learning, but here's a REALLY GOOD video from one of our members http://leatherworker.net/forum/index.php?showtopic=12259 Here's another one he did about how to sharpen your awl, since it's something that a lot of people have troubles with. http://leatherworker.net/forum/index.php?showtopic=47996 Hopefully these pictures about edging will show others that Gum Trag is NOT necessary to get a good edge easily. I continuously tell people it's just a crutch and only glues things down. It should be clear that this edge is smooth and will hold on its own without the aid of something holding the fibers down. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Eternal Custom Designs Posted June 21, 2013 Author Members Report Posted June 21, 2013 Very true...thanks again...I was just telling my wife how much of a help you have been!!! I appreciate you brother!! Quote
Members Eternal Custom Designs Posted June 21, 2013 Author Members Report Posted June 21, 2013 What of after application of your dye...if its too dark can anything be done...I need to work on application techniques somehow...suggestions??? Its a dif ball game from scraps to strap lemgths Quote
Members Cyberthrasher Posted June 21, 2013 Members Report Posted June 21, 2013 What of after application of your dye...if its too dark can anything be done.. Not really. Since the dye soaks into the leather, you can't remove it. Is it only too dark in certain areas? If so, apply a light coat of neatsfoot oil over the whole thing and then just let it sit. The dye may even itself out. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Eternal Custom Designs Posted June 21, 2013 Author Members Report Posted June 21, 2013 I like the look actually..its darker on the edges cause I did the edges first...its a cool look...I'm gonna try airbrush soon...to build layers...but like I was saying I don't know how to practice..cause its easy on scraps... Quote
Members Cyberthrasher Posted June 21, 2013 Members Report Posted June 21, 2013 How big are your scraps? When testing coloring, I like to use stuff about the size of a post card or so. But, for overall single color, I use the rag method that we were discussing and just wipe it on. It's easy to get even coverage that way without building up too much. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Eternal Custom Designs Posted June 21, 2013 Author Members Report Posted June 21, 2013 My scraps aren't that big...so was it u that uses and old T-shirt? Or how do you do it.... I decided to put another coat on to even it out!! Lol...it was eating at me!! Quote
Members Cyberthrasher Posted June 21, 2013 Members Report Posted June 21, 2013 Just remember that dye can take time, so let it do it's thing before you panic too much. You'll be amazed at how it evens out over time. I think that was Tom who said he uses the old T-shirt for resolene. I'm a sock or blue shop paper towel kind of guy I stopped using the towels for Resolene, but still use them for dye all the time. Just fold it up into 1/4's, hold it over the dye bottle, and splash some up there. Wipe that on and it will be perfectly even. You'll have to reload a lot, but you won't get streaks or uneven spots as easily. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
