  • Replies 120
  • Created
  • Last Reply
Top Posters In This Topic
So, for the streaks, you'll need to either lighten up your pressure or make SURE it's cut 50/50 with water. Perhaps you need just a little more water in it. Nothing you can really do to get rid of the ones that are there, but it's possible that the next coat will even some of that out and hide it.
Did you pick up a bone folder at all? If not, they have them at Joanne's, and most likely Micheal's. You can try to use that to clean up some of these spots. But, first we have to take care of that line. It's pretty good in spots, so we're going to have to make it look like you meant to do it the best we can :)
Find the line that's the furthest from the edge on the entire strap - we'll use that as a baseline to try to make it look right. If you have some wing dividers, set them at that width. If not, find something you can use to make that line the same distance from the edge all around. Hopefully MOST of it will be pretty close to that point and you can maneuver the leather some and do some rubbing to make it look like it was meant to be. The stuff that's closer to the edge will need to be rubbed out the best you can - preferably with the bone folder or a modeling tool. It looks like they're all pretty close by viewing pictures 1 and 3. Just get that top edge damp and take your time trying to get your line as straight as possible to make it a border. Not sure what you're using to mark your design, but you can even use a stylus if you have to to get that thing going.
post-22094-0-13177600-1371781564_thumb.j
post-22094-0-96693200-1371781565_thumb.j
post-22094-0-82210000-1371781567_thumb.j
Once we get that happy little line and it looks like it was done on purpose, I want to see you get that bone folder going and use it to slick up the edges on the spots that are sticking up. Think of it as a touch up burnisher. The far left side of picture 3 actually looks pretty good with maybe just a little roughness on the back edge that can be touched up this way. Let's use that as a baseline.
OK let's see if we're on the same page...tomorrow I'll look for my bone folder...if I don't find it, on the other End of my stylus is I think what your referring to as the modeling end...(its kind of spoon shaped)...basically which ever line that the burnishing made that is furthest away use as the starting point for an edge all the way around..I can just wet the surface and use my stylus to make the border right? Then using the modeler push down only from the line I made as a border outwards towards the burned edges I've started... and I started using my mini mag light to burnish all the edges my cheapo undersized burnisher didn't get...lol..does that sound like I understood? When u burnish the edges do you use water...I think I used to much water making it to supple..never again
* burnished edges
Also I'm just using the weight of the foam brush when I apply the resolene..I had to point them out to my wife..but there still there and it bothers me
* burnished edges
Sounds like you got it. Once the line's made, just use that modeling tool to even things out and try getting a flat surface from the line to the edge - smoothing out the mistakes that are closer to the edge than your baseline. I'm having you use water here because you're making the line and smoothing out some other stuff. That will make it toolable for you.
Normally I don't really use any water when I burnish my edges - just bar saddle soap rubbed in. I have a groove worn into the bar that fits most of my leather perfect right now. That's most likely what happened here - too much moisture and it just caved. You can use the denim to polish things up pretty nicely. Just rub it fast and hot. I have one piece loaded with beeswax to wax my edge up and then a dry piece that I used to really polish them. Most of my burnishing is done with a cocobolo dremel burnisher, but there's not reason not to be able to get the same results by hand - just takes more time.
Did you get the foam brush wet? Try a plain sponge and see if it's any different. I know those foam brushes can really suck up some material. It may be holding too much and squeezing it out on you. If you get it wet first, it won't suck up as much, and that will help to make sure your not applying too thick.
I get 10 packs of sponges from the dollar store and cut them up into 6 - 8 pieces each and use those for wetting things down and applying Resolene. I'll have to test sometime to see if the sponge holds any differently than those foam brushes. Doubt I'll be able to see in time to help you on this though.
I'll do some more tests tomorrow... I'm gonna dilute the 50/50 reduction with a bit more water and give one more coat tonight and let her sit overnight.. the only streaks are in an area that the spikes are going to be attached...but if I don't at least work at it it will ear at me...thanks again for everything brother!! I'll keep u posted!!
Man, I've never made a SINGLE item without something on it that drives me nuts. You just have to see it, study it, find out what went wrong, and study your butt off to solve the problem and learn from it.
I've used a number of things to apply the 50/50 res. What I like best is an old cotton shirt - not a tee shirt but a dress shirt type material. I used a small square folded in half. I put it on the edge of the bottle, tip the juice onto the cloth. Then I strike a quick stroke on my newsprint that I use to see how much I'll be laying down and then wipe the surface of the leather.
Works perfect. Lays down a microthin layer.
What area of the country do you live in?
