Members jeimert Posted June 27, 2013 Members Report Posted June 27, 2013 I have found a local upholstery guy who has a pfaff machine sitting in his shop that he doesn't use and wants to sell for a great price. He does not know how to use the double needle option on the pfaff so it is rendedered useless to him and basically giving it away at $250. I have looked around the whole machine and can't find any information on what model it is just alot of numbers that I have pictures to. Does anyone have experiance identifying these machines? because the google searches I have done do not come up with any methods of asertaining the model. any help would be appreciated! Quote
Members camano ridge Posted June 28, 2013 Members Report Posted June 28, 2013 As it says on the plate it is PFAFF 134 if it has the bar for the double needle then it is probably a PFAFF 134-0-92. If you google PFAFF 134 or SYSTEM 134 PFAFF you should find information including you tube videos parts manuals etc. If everything works the price is probably pretty good. Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Trox Posted July 1, 2013 Report Posted July 1, 2013 Hi, The model number is on the brass plate on your first picture: Class, subclass and equipment. Then type "B" and "L" stands for leather normally with Pfaff. The 134 number on the needle plate is the needle system Schmetz 134. Thats a short needle system used on many German sewing machines before. (like Adler 67 and 69 and older Pfaff) I do not know this machine class. However, it looks like a zigzag to me. I cannot tell without seeing the hole needle plate. If you send the number on the brass sign to Pfaff http://www.pfaff-industrial.com/pfaff/en/pfaffstart?set_language=en&cl=en they will provide you with info you need. I see the first letter on the brass plate is under the nail, you better send the picture to them too, or the link to this post. The people in Pfaff is very helpful, I am sure they will give you the info you need. Good luck Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
