Hi all,
I need to use a strap end cutter for about 30 belts at a time, and I was wondering if there is a faster way anyone could recommend than using a poly/rawhide mallet and doing them by hand. I considered using an arbor press but the strap end cutters I have are too wide at the top - about 3/4" - to be able to drill in to the arm, or too long - about 5 1/2 " - to fit under the press arm.
I think I am missing a trick here somehow, and would appreciate some advice. Fitting each strap into a jig, and pressing them would be both fast and accurate too - at least that was the train of thought I was having on the subject.
Any advice from you seasoned strap cutters out there in Leatherworker land, as I am stumped on this one!
Thanks a million in advance.
Kevin
Nickelsafe, UK
