sjstates
Antiquing Help
When I was applying some RTC over my antique it picked up and smeared some of the antique where I don't want it. Is there a easy fix for this?
Sometimes you can fix it if you clean it up immediately.......
Whenever you apply finish over your antique, use light pressure and make sure you're not using an applicator that will go down into the tooling to pull the antique out. Also, make sure you're letting your antique dry long enough. Give it some time to cure and harden up a little bit so it doesn't pull out as easily.
Thanks guys I appreciate the help
