Members Lacosta Posted August 7, 2013 Members Report Posted August 7, 2013 Hi Everyone, I am looking for a suede or leather trim that has tiny scallops on one edge with a tiny stud in each scallop. The other end would be wide enough to sew. I see this trim on tons of purses and cannot find where to aquire it. Last resort is to make it - where to purchase a GOOD scallop leather sissors? Anyone run across this or is using it? Thanks a Ton Quote
Contributing Member Bob Blea Posted August 8, 2013 Contributing Member Report Posted August 8, 2013 Hello Lacosta, I haven't seen a premade trim like this. Have you tried searching Etsy for someone selling this in one of their shops? There are a lot of people there that sell raw material for making other crafts, and maybe someone there has something that will work for you. I've tried a few of the scalloped scissors made for paper crafts and so far I haven't found any that work really well for cutting paper consistently, let alone leather. If I were going to make a scalloped trim I would cut the suede to the size I needed then I would use a half round punch to punch out the individual scallops. Bob Quote There are always possibilities.... Bob Blea C and B Leathercrafts Fort Collins, CO Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop Instagram @bobbleacandbleather
Members ChuckBurrows Posted August 8, 2013 Members Report Posted August 8, 2013 I make my own by using strips of the appropriate sized leather (I make it a bit wider than needed and after scalloping I trim to the correct width) and for the scallops there are no scissors available that I know of so I use a round punch of the appropriate diameter and grind off half of one side to make it a half round. This is a pic of one of my pairs of botas on which I used fairly large scallops, but I have made them as small as 1/4" with a 1/8" spot in the center Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
Members ChuckBurrows Posted August 8, 2013 Members Report Posted August 8, 2013 or you can get a pinking punch like these http://brucejohnsonleather.com/content/index.php/leather_tools_for_sale/leather-punches-concho-slot-strap-end-and-hole-punches/ On softer leathers it also helps to tape the back side with blue tape -it helps keep the leather from loosing it's shape Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
Members Lacosta Posted August 12, 2013 Author Members Report Posted August 12, 2013 Thanks Chuck & Bob for your input. Some tool maker should design a punch in different sizes with several in a row as well as a single. Probably sell a ton. Thanks again Quote
Members Lacosta Posted August 12, 2013 Author Members Report Posted August 12, 2013 Ask and you shall recieve - Bruce Johnson leather has 1/2 round punches! Thanks Bruce Quote
Members gracefulmeg Posted February 9, 2017 Members Report Posted February 9, 2017 I remember finding this feed a while back and I've finally figured out how to get lots of different scallops. I made a video about this here hoping it will help someone who finds this later. Quote
Members wlg190861 Posted February 10, 2017 Members Report Posted February 10, 2017 Found these on ebay http://www.ebay.com/itm/Whatwears-WHATWEARS-Fabric-Decorative-Edge-Pinking-Shears-Scissors-Large-Scallop-/112204446092?hash=item1a1fe7f98c:g:pHUAAOSwzaJX2vOl Quote
