Members Ski Posted August 23, 2013 Members Report Posted August 23, 2013 Hi All, Soon I will attempt to stitch with a curved awl and curved needle. Its the only way forward for the finish I want (to join two pieces of leather, to appear flat). Ive got a Al Stohlman book which describes what to do, but was wondering if anyone had any other useful information, if from experience or a link to a video to help me. Not much information out there. I will be attempting a rounded cigar holder, the edges must be rounded, I assume the only way forward is to carve a mould from wood then stich using a curved awl / needle. Any tips or help most welcomed Quote Warm regards, Mark Skiba
Members gary Posted August 23, 2013 Members Report Posted August 23, 2013 I have found that, when butt-stitching (oh my, that should get a few chuckles given the transatlantic audience), get the stitches on each piece to line up as closely as possible. Use a robust form of some sort to stitch on - plastic pipe is good but if you're box stitching a base onto it, use something with a solid base. I currently use fence post off-cuts as the wood is kind to the awl blade when you clip it doing a box stitch. Go through the first side quite strongly and then be really tentative going through the second side; if the point of the awl starts coming out in the wrong place, pull back and try a slightly different angle. If you have a curved needle I have found these to be too curved and need a little bit of straightening. If you're making your own curved needle, as Stohlman shows, don't heat it too much before bending. Hope that helps. Quote
Members Ski Posted August 23, 2013 Author Members Report Posted August 23, 2013 Yes these are the exact tips I need. I will be making my own awl and needle, thank you for the tips and I welcome more Quote Warm regards, Mark Skiba
Members silverwingit Posted August 24, 2013 Members Report Posted August 24, 2013 Not using a curved awl & needle, this is the approach that Nigel Armitage uses. Worth a look anyway! Michelle Quote
